Dear All,
i was pondering the lack of output adjustment if using the Discrete o/p. Is there any good reason why one shouldn't replace R6(100k) with a 100klog pot as a fader, with the wiper feeding +ve input of op-amp, and the opa-amp circuit configured to give say, 20dB(more than enough imo)?
Also, I have given up trying to get a revlog 5k pot. I still don't understand what it is v.v. a normal log pot. Is it anti-log, log backwards, or what? Seems to depend on who you ask. Some say lin pot with resistor strapped over pins 1 and 2, some say rear section of dual log pot, - Nuts! I say! I was thinking of using a pre-set to establish correct value for set ratio and using a switch, say, 2:1/3:1/5:1/8:1/lim? Any reason why not? Also considering doing the same for Attack/Release values. Makes for a much more accurate re-call . . . . . . maybe threshold too . . . .
Also, can i use TLO72 or NE5532 in this circuit instead of OPA2604 with reduced Voltage rails (+/- 15v)
Does anyone have any experience using an analogue vu meter in this circuit? I need help with the value of resistor between meter and ground, and value of trimpot to give 0dB if at all possible. . . .
Finally, has anyone plotted any resonse curves for one of these babies? i guess it would be helpful in finding the values for ratio switch and also for analogue gr meter . . . . .
eagerly awaiting my opto-isolators . . . .
Many, many thanks in advance, you wonderful, wonderful, people . .
Andy P .
