Getting ready to finish my FF opto comp, and was wondering if anyone has tackled the make-up gain issue yet? I'm using JFET 992's as an output amp.
My plan is to use a rotary switch to switch a shunt resistor to ground just after R8 (right before the opto element in the audio path). I figure if I set up the output amp for about 10dB gain I can set up the switch as a pad. This would give me a range of say -2dB to +10 dB for make-up (1dB steps on a 12 posn switch, probably good enough for my needs).
I figure this approach is better than messing with the feedback of the output amp, as that will change the bandwidth, and sound as gain is changed.
I gave up on the 5K rev log pos, and bought 12posn switches for that one too. I figure I'll just try out some values, and see what works out best. I'll probably only use 6 ratios at most
Kris
