ricardo said:
Very few people know about this polystyrene microphony and even fewer have tested it. Rossi, you've just joined this very august group .. and I'm not being snide
There
may be mike designers who like microphonic electronics in mikes ;D You decide if this is competence.
There are loadsa mikes 'designed' with 2sk170 too.
It may be that these 'designers' never measure the real life noise performance of their mikes. I fully appreciate that some parts may have Golden Pinnae sound but I prefer eg caps to behave like caps should and get my 'sound' via other means.
Rossi, why don't you listen to the microphony as I suggested earlier. You at least have taken the trouble to investigate it. Its a very short step to putting some numbers on this 'feature' and then deciding if
- it will be audible
- you like it
This is in the end, what we are striving for.
Yes. Electronics that don't add 'sound' to a microphone is a religion for me.
Anyone have a modern Schoeps body and is willing to take it apart? I'd dearly love to know what Dip Ing Wuttke used in his last designs when he wasn't faced with the constraints we had in the 80's
Polysterene is not very popular these days, except in vintage/retro designs for period correctness.
Polypropylene is what's mostly used today, and I think it's for sound reasons (pun intended). And I'm talking about real designs by reputable manufacturers, not Chinese contraptions which indeed often use 2SK170 and inferior grade ceramics.
Polypropylene may be slightly more microphonic than C0G, but not enough so to cause trouble. As I've said, in my tests polypropylene sounded cleaner than C0G. It was a bit closer to the plain wire (non-)sound. This may be contrary to what you
know but I doubt it's contrary to what you
hear, if you do a comparison. Also, this is an application that's not widely tested: extremely high impedance and an uncommonly high voltage differential of about 60 volts. Plus the signal levels can be quite high. Many a large diaphragm capsule puts out around 25 mV/Pa, so we're talking about several volts RMS once we approach the mic's max SPL figure. Those are conditions far beyond the Bateman measurement scenarios.
So while I investigate some more into the microphony issue, why don't you make actual listening comparisons of different input caps, polypropylene and C0G in particular.
The mic input cap is the one area where I don't want any sound coloration. However, I'm not averse to some coloration further down the signal chain, depending on what the mic aims for. There are applications for very clean mics and there are applications for somewhat colored mics. I've built both, and I find it more challenging to build a mic that has a (good) sound of its own, because your goal is a subjective one and it can take a lot of time to refine such a circuit. Clean mic circuits aren't exactly easy, either, but at least you have a clear target to aim for.
On the Schoeps site, there is a pic of the internals of their new V4U vocal mic. It uses a new circuit design which gives higher SPL handling than the CMC circuit. However, I doubt Wuttke designed it, since he retired a few years ago (although he's still involved with Schoeps). As a matter of fact, I'm not sure Jörg Wuttke designed the well known CMC circuit. One of its predecessors, the CMT30 already used a very similar circuit - differences are merely in the DC converter section and a few component values in the actual amplifier). According to www.schoepsclassics.de the CMT series appeared in 1965, which predates the Wuttke era. I don't own a modern day Schoeps, but as far as I know the CMC5/6 still uses the same basic circuit, but I don't know anything about its component choices except that it uses SMD components.
