Oktava 319 with hum issue.
RichardP
New member
Australia
I have a Joly modded Oktava 319 - but have unfortunately dropped it. It now hums at 50 hz. It would seem that I now have a grounding connection issue.
I have noticed that if I touch the base of the microphone with one hand and the top of the basket with the other the hum disappears.
However, if I touch the base of the microphone with one hand and the side of the basket with the other, it makes no difference to the hum.
Would this suggest a connection issue between the top and the side? Certainly, the original epoxy has worn down a little (the mod is nearly 16 years old).
Could there be anything else that might explain the hum ( the screw in the centre of the diaphragm is stable)?
Much appreciated
RichardP
Definitely sounds like you diagnose is correct 👍
Edit: Would expect more like a buzz than hum though. But the fact that grounding the head basket with your hand makes the noise go away nevertheless implies it's a grounding issue.
Thank you for your reply. (I guess it is more like a buzz than hum)
I've tightened the screws on the head basket which did not change anything (and other screws as well)
I guess I should look around Pin 1 and also consider re-expoxying the top mesh to the basket (given that only touching the top mesh in combination with the xlr shell seems to take away most of the noise).
Is there anything else you could recommend that I should be looking at in the first instance?
Many thanks
