Takstar CM-60 and CM-63 capsule mods.
This capsule was mentioned in another thread, so I purchased it to see what it was like. It doesn't actually fit the cm63 (the bolt protrudes too far), but I was able to swap the innards from the original cm63 capsule to make a 'frankencapsule'. I haven't set up REW to do any proper tests, but it does seem to have less of the exaggerated high frequency response compared to the original. The capsule may be a little further back than is optimal, but the front grill may be an improvement on the original.
The price fluctuates a bit, but I was able to get it for €5.46 once the taxes and a €1 discount were applied. For this price, it's probably worth buying just for the capsule parts.
Link to the Aliexpress page
I agree it is a nice little capsule for very little money. My example, acquired on eBay.com, may vary slightly from yours. in that it fit my CM-60 body OK. (Not the smoothest threads, but it fits.) And, Also, my example seems a bit louder and a bit more open (brighter) than my original CM-60 capsule, but not by much. Both are less bright than a 22 mm MXL 700 capsule I also tried. Because I have faith in the accuracy of your description, I suspect they vary slightly from one to the next. While I have two of them, and they sound identical, I suspect yours may vary a bity from mine which is not entirely unexpected!
I decided to use the original CM-60 capsule - but I can see your example may sound better than mine, so I get it. I was pleased my example threaded onto the Takstar body easily enough - that makes a big difference to its usability. Fun stuff. James
A couple of crude, unprecessed sound clips - brass eBay capsule, then original CM-60 capsule, then 22mm MXL 700 capsule. You be the judge! :)
View attachment 22mm capsule comparison 1a.wav
View attachment 22mm capsule comparison 2.wav
