Cause of fault found.
Finally my multimeter arrived so I measured 47uF cap. It measured 28uF. I tested the mic with 47uF cap open (one pin unsoldered) and the tone is gone. Looks like the cap was bad. Panasonic radial electrolytic caps will arrive next week, so I'll replace all 3 in each mic. Thanks for pointing to the 47uF being the cause!
Now that the mic is fixed, I want to concentrate on the rest of the components. Many of you have disagreed with Joly's choose of the Silver Mica (is that the Big brown cap on my photo? ) instead of a C0G. Is C0G definitely better, should I replace silver mica with this one (I've ordered it already just in case)?
https://www.digikey.it/product-detail/en/murata-electronics/RCE5C2A821J0M1H03A/490-7493-1-ND/4277410
If C0G is better, then what's the logic of a knowledgeable guy like Mike Joly behind using a silver mica? Do they have any advantages over C0G for sound?
Lastly, I want to replace the Russian FET with Toshiba 2SK170 BL. But I hope to get your guys clarification about the C0G vs Silver Mica.
