In regards to ArR schematic,
zebra50 said:
I'm surprised to see the 2.2uF electrolytic cap at the rear capsule pattern selector. Might be a good candidate for an upgrade.
I'm not that much surprised that it's an electro, since even the output coupling cap is an electro! I agree that it could be upgraded...
But I wonder how long does it takes to reach the desired voltage when changing pattern?
About the filter cap at the trimmer/1G junction... Well, the 2.2µF is only about 500K from there.
The trimmer saves on matching resistor indeed, but it may also makes up for capsule tolerance, or allows to dial in different polarization voltage in order to 'tweak' the sound...
@Cmuller0420
Don't worry about the middle pin, the original tube didn't have one, it's just there for convenient wiring...
I suggest to start with a good cleaning of the components and wires... High impedance circuits do not like dirt... Wait for all the voltages to fall down to zero, and use a qtip with isopropylic alcohol. Do NOT touch anything with your fingers once it's done!
Also, some tubes do not like underheating. that may be the case for your 6AK5. You could try to set the heater to 6V and see if that improves noise.
Axel
(edited a spelling mistake)
