1G resistors are very expensive
Not necessarily Sure, not quite the 2 cents a more usual value would cost, but sub 1eu is still towards the affordable end, I'd say.
https://www.mouser.fi/ProductDetail...=sGAEpiMZZMtlubZbdhIBIFho3SHfDXSt5nRQ4pdsqnc=
Is the mic supply ground at the same location as the ground of the equipment the mic is feeding? Had problems before with ground loops where the mic power supply has its power earth connected to equipment looping via the main switchboard creating a hum loop, or long mains earth distance between source and target compared to short audio earth (or vice-versa) Didn’t affect all - just some mics. One was an old Telefunken.Wow that's cheap,
I remember some years ago I needed 1G resistors to modify an MK-219 and I paid a lot, I remember at the time it was the cheapest my supplier had, can't remember if it was Farnell or Mouser.
Thanks for the link,
now I'm going to go back continuing to troubleshoot my MKL-5000.
Bought a couple of extra 6AK5 tubes to try out, I don't think the Low-End hum I'm having is from the present tube, but well it doesn't hurt to try out with a different tube.
Otherwise I'm a bit on a dead end here, as I already did all the mods to the PSU and the Mic that were suggested to reduce noise in the various MKL2500 and MKL5000 threads
Meter check earth continuity all the way to the mesh I presume?The problem is really in the MKL-5000 microphone itself
