Yeah, I’ve had a hard time sourcing anything close.That's an unusual combination. Relatively low plate voltage and current with a rather high filament current (and CT as well). What sort of packaging is it in....and what device requires those specs?
A quick glance at https://www.hammfg.com/electronics/transformers/power didn't come up with anything, and they have a LOT of choices.
Bri
At a glance looks like the infamous altec 1567 or 436 transformers
Thank you! You’re totally right. A voltage doubler is used. A selenium rectifier.These are actually rather rare values, B+ seems to be either very low or a voltage doubler (see @emrr ) is used. If this is the case, you can better look for a transformer with the correct target voltage for a normal rectifier.
Not really, I have seen similar things in several US schematics. The Altec 436 also has this.Here’s the schematic if you wanted to take a look! It is a weird one!
You could use two separate transformers, one for plate, one for heaters.Does anyone have a recommendation for a power transformer with these specs that’s readily available???
lol. Yerpppah, RCA supply
Might have to just abandon making this exact power supply and look toward something with the same output. I’ve been using a Heathkit Power supply, but I’m worried it won’t be able to power the new rendition of the console I’m building. It worked well with the old version.Heathkit 54-59 over specced a bit.... 54-81 a bit weak.... heater tap can't pull the extra current can it??
may be others....stopped there....
https://reverb.com/item/52225297-gr...t-vintage-power-transformer-tested-6-3-v-1954
Yeah, I believe that’s the call. Nothing seems to be matching up just right. As I’d mentioned, I used a Heathkit variable power supply which worked well for the 5 channel console I built, but I’m rebuilding it into a 10 channel board with direct outs, two buses, and an echo send. Not sure the Heathkit could handle allllll of that.You could use two separate transformers, one for plate, one for heaters.
But yeah, it might be easier to just change the voltage doubler to an ordinary rectifier and use a 225V-ish tube amp transformer.
The total heater current for the "new build" should be easy to calculate; just add up the current from each of the tubes. The B+ is trickier....does the Heath have a current meter?
Regardless, for the B+ download the FREE PSU Designer app offered by Duncan Amps. You can "what if" a ton of variables to arrive at a good solution.
Bri
PS, if doing a new build, don't overlook the toroidal transformers from Antek....excellent value.
With such a high current requirement, a good quality switch mode power supply (SMPS) with some additional filtering would be the better option for the filament voltage.Oh yikes… well… the Heath is an SP-2717A, which is 6.3 VAC @ 4 Amperes… my new build is @ 10.2 Amperes…
Agree. With that much current this is a perfect use case for switch mode. If its a new build you may be able to strap the heaters for 12.6v and use any commonly available 12V smps with the appropriate wattage. Cheap and cheerful, even with extra filtering (which may or may not be necessary for heater strings, but doesn’t hurt).With such a high current requirement, a good quality switch mode power supply (SMPS) with some additional filtering would be the better option for the filament voltage.
Check this link:
https://groupdiy.com/threads/switching-psu-filtering.80123/
