Analog_Fan
Mouser announces February 2023, Digikey doesn't say anything.
Well, i have quite a few designs (voltage controlled filters) on stock, i made of the past year and now ...according to TI it is still an active part but I would avoid old OTAs for new designs.
I used LM13600 in a voltage (actually current) controlled sine wave generator (10Hz to 30kHz @ <0.3% THD) inside the Loftech TS-1audio test set, I designed back in the early 80s. It was the right technology for 40 years ago...Well, i have quite a few designs (voltage controlled filters) on stock, i made of the past year and now ...
Mouser says, they arrive in 2023.
the problem is, i use the 1V/oct control circuit from the Korg MS-20 filter.I used LM13600 in a voltage (actually current) controlled sine wave generator (10Hz to 30kHz @ <0.3% THD) inside the Loftech TS-1audio test set, I designed back in the early 80s. It was the right technology for 40 years ago...
I have designed a couple of things (but not yet build) using matched transistor to build the LM13700.Welcome to the Great Reset and artificial scarcity.
It's not just the LM13700. TI are quoting mid to late 2023 deliveries for the LM3886, OPA2134 and lots of other parts.
NJE dropped the 13700 a couple of years back and I bought some before they went EOL despite having never used them in a design.
