[quote author="tv"]In such case you'll be having 4,5V across the input cap in series with a couple megs resistor trying to impress the pickup with some voltage. You will need to pulldown the input to avoid thumps etc when plugging/unplugging the instrument(s) - i.e. when the input isn't shorted with the jack as drawn on the schem.
Not saying that this "will" happen, just that there is some*** probability to happen.
DC-coupled discrete fet inputs otoh are relatively free from such phenomenons, but they can have other issues.[/quote]
It is what I intended to do implementing discrete input in the 1'st version with 1 megOhm input resistor. People said it should be higher, so now it is 5.1 megaOhm and an opamp for simplicity. However, I can use couple of batteries for better coupling (and dpdt foot switches I don't have), but I definitely need a HPF because the last time digital delay processor clipped causing thumps when some people hardly hit their strings.
Speaking of thumps and other noises I'll instruct all of them to plug in/out guitars only when LEDs don't shine and tell how to use foot switches (there will be big concert with multiple bards: 70'th anniversary of Vladimir Vysotsky).
Anyway, I'll use faders for backup if I see somebody wants to plug in/out.
