Hi from NYD two-bottle newbie land.
I'm finally making two channels of the two-bottle pre, and when ordering some of the last parts, ran into a bit of trouble. The PSU transformer. As of now I couldn't find a perfect match, but how about something like this to power the two channels:
35VA toroidal 230// 6,3V 2A / 215-0-215V 0,05A
too small?
or
143VA toroidal 230 V // 280-0-55-280V 0,15 A / 6,3 V 7 A / 5V 3A
way too big? or maybe I should keep looking still?
When I ordered some 12AV7's, I was suggested to use the 5965A instead. The tube guy said it is basically an improved design of the 12AV7. Just for kicks, I ordered one for swap-in testing, but what do you guys think about it?
Regarding the stepped unbalanced attenuator, does it go before or after the output transformer? I suspect it goes before the trafo, but just making absolutely sure.
Oh by the way, the two channels won't be identical, I already got jensen transformers for the other channel, and haven't still decided what to use for the other. Would these OEP's be good http://www.farnell.com/datasheets/9126.pdf
1+1:6.45+6.45 for the input, 1+1:2+2 model (turned around) for the output? Gyraf G9 uses these so I thought they have to be pretty ok.
Mike
