skal1
At some point yes , at the moment no funds ... thanks
skal1
skal1
Don't see why not. As far as I'm concerned if you're going to go the point to point route, then soldering the components as close as possible to where they have effect is actually good practise, not poor. Especially for very high impedance points like grids e.g. soldering grid stoppers and HF filter (miller) caps directly onto the tube socket. I'd rather see a logical point to point layout of components arranged following the signal path and preferably something like in a circle around a tube socket, rather than a nice row of components neatly lined up in parallel with their color codes all in line on a tag board. All of that extra cable just adds extra/unpredictable coupling paths.mac said:One other quick survey question. Is it poor practice to attach the zobel network components directly to the input transformer? I notice a few layouts have these components on the tag board an then run screened cable to the trafo.
Mac
Early days for me with p2p (tag boards) and tubes...
C4 doesn't just interact with R10. That's the least important resistance to consider. R10 is mainly there to prevent the output floating higher than 0V (due to leakages etc). More importantly, C4 also interacts with Rp (the plate impedance) and don't forget the load impedance, which is not shown on the schematic. Both of these resistances are generally much lower than R10. 0.47uF is almost 5 times smaller than 2.2uF, so the LF roll off will kick in at ~5 times higher the frequency. Impedance of 0.47uF is 8K at 42Hz (low E). It will almost certainly affect the low frequency response and probably make your pre much more load dependent.mac said:Thanks for the responses guys, and the extra reading ;D
As I said up the page - I am not too worried about this first layout, as I new it was a rough and ready rig - put together to learn - before having a go at a good and robust layout.
The other thing I am trying to get my head around, is the DC blocking cap in C4 (designated on Dave's design as 2.2uf). What impact does lower / higher capacitance have on the circuit in this position? I understand that it is working with R10 (220k) to block DC (+106v) and to present appropriate impedance to the output, but I have some 0.47uf caps here that I would like to use, and wasn't sure if I should be changing the value of R10 accordingly. Does lowering the capacitance increase the LF rolloff of the output?
Mac
bluesbaz said:I've bult these with a shure m68 input transformer (1:10) and it seems i have little control over the gain. The rest of the circuit is the same. Any ideas where I should be looking?
-Thanks
mac said:Is there any concerns in tying two channels together with one single "ground buss" arrangement? see sketch attached...
It is a beautiful gigantic old thing TA746 6000:600 centre tapped on the primary.
