tk@halmi
Hey, Dave's preamp could be really cool coupled with his Line Output circuit and drive a 600 ohm transformer. Hmm...
However, triode is better here: Pentodes have noise issues, and we don't want the tremendous gain that a pentode is capable of. He picked that particular 5879 tube because it was manufactured for audio applications, including low-noise when triode strapped. There are a half-ton of other triodes you could use instead, but you may have to buy several extras and select for low noise. With 5879, you are unlikely to run into a hisser, and it isn't expensive. (It has also been featured in some notoriously famous audio gear, but so what?)
For the One-Bottle pre, or this new "Two-Bottle" idea, you'd use a 10K:600 output, wired in the normal fashion (using the whole primary and the whole secondary). A 5:1 (15K:600) output would work fine, too. Your max output level would be less, but the distortion near max output would be reduced, too (due to slightly lighter loading of the output stage). Just make sure those small 5:1 jobs are intended for use as output xfmrs, not inputs! They should be rated to handle +20dBM or more.
