It seems so. Fortunately, it shouldn't be too difficult to replace.Is the 4013 busted?
They areMake sure pins 8 and 10 are definitely connected to ground.
Have you checked the pulse going to pin 11? Could that be that C6 is leaky?Well, I replaced the 4013, twice actually. No luck. It will only toggle and stay LOW if I don't release the switch button.
The plot thickens! Have you checked with a scope the signal on pin 11?Replaced C6. No joy. Same behavior.
Don't have a scopeThe plot thickens! Have you checked with a scope the signal on pin 11?
The original part that I replaced is Toshiba TC4013. The other pedal in the same series that I have also use the same switching circuit board, albeit an early design with through hole components, Toshiba TC4013 and TC4503, and has a different pinout going to the FX board. I tried it with this FX board after I arranged the pinout, and it work flawlessly.CD4013 doesn't have a schmitt input, I think. Does it sometimes work if you kinda 'snap' the button really fast? I had a similar problem once where I had to swap to a HEF4013 which does have a schmitt input and can cope with slow trigger rise times.
You were right. I did what you suggested, and it toggled. But it took several attempts. Not good.CD4013 doesn't have a schmitt input, I think. Does it sometimes work if you kinda 'snap' the button really fast? I had a similar problem once where I had to swap to a HEF4013 which does have a schmitt input and can cope with slow trigger rise times.
No difference either with a new momentary switch, hence the reason why I soldered back the old switch.This can happen as a switch ages / wears.
Hit and miss whether it will work okay with a particular individual IC as it may be working in the "Undefined" area between the specified hi / low logic voltages.
Fig 9 in the TI CD4013B datasheet suggests using a SN74LVC1G17 to do that. However, not suitable to your case since max V is 5.5V and DIY unfriendly package.Let's say theoretically, the switching problem can be resolved by adding a Schmitt trigger input, is it possible to do something like this? Switch to Input A, and Output B to CD4013?
Slightly off topic, sorry. Is Vanxy a reliable seller? I bought some pedestrian components from them (2n3904-06, TL072, etc.) and some jfet that seems to work in my stomp box projects but I tend to distrust Ali Express.HEF4013 is available from Vanxy
Damn, I hate these logic ICs. They are so unreliable.
Don't have a scope
What is the value of R119? Do you see the LED blink or flicker at all when the switch is pressed?
Yes of courseLet's say theoretically, the switching problem can be resolved by adding a Schmitt trigger input, is it possible to do something like this? Switch to Input A, and Output B to CD4013?
