edanderson
see page 4 of the 990 pdf, figure 1, the circuit in the dotted line:
http://johnhardyco.com/pdf/990.pdf
i have gotten this to work in a circuit where the gain is constant. the effect is that the output dc offset created by the input device bias current is canceled out. i have yet to test longterm thermal stability, but this seems to be an effective way of reducing the offset, if not to zero then close.
why don't more people implement this type of circuit? in my (thus far limited) experience, it seems to work, the parts cost is low, and i haven't found a large difference other performance aspects. there is another variation on the same idea presented later in the 990 paper. even if you are using a servo (as the MPC-1 does) the nulling circuit seems like a good idea.
thoughts?
ed
thoughts?
ed
