Don't see what you did there. Went with Primary +/- to S1+/- and Secondary to S2?
and finally? FD to plate and P1+ to the center capsule?
Not at all...
Primary winding has two wires, right? That's what the "P+" and "P-" pads are for... "P" standing for "Primary" (positive and negative, as it were)
FD = Front Diaphragm; BP = BackPlate
If you have a single secondary winding, that goes between S1+ and S2- (by the same logic as the primary).
If you have a center-tapped secondary, center tap goes to S1-/S2+ (they're connected together), and you can skip the two 2k2 resistors. If you have two separate secondaries, same story.
Please, please, PLEASE try to read what i write...
