OPEN SOURCE DIY Mic Project - ORS 87 - Stripped Down u87
Cheap capsules produce harsh high frequencies that cannot be leveled with a transformer, and some capsules even remove the high frequencies altogether.
Not all cheap capsules have the same FR. On the contrary, there is a large dispersion of parameters. So we don't generalize, some cheap capsules have a pretty good FR shape in the 3-5kHz area where sibilance, harsh etc. are produced more frequently (which depend on the sound sources, voices), but they only have exaggerations in the higher highs. Let's just mention the 797 and Takstar capsules, which have more air than the Neumann.
I use with good results some Chinese transformers in the 87 topology, through a steeper Deemphasis only in the upper trebles.
Example: cts-2 from p420
@kingkorg 's research confirms the ATK measurements I have high confidence in.
    346.8 KB
    3.1 MB
    112.5 KB
Recently received the boards that I ordered from Chinese comrades here:
https://aliexpress.ru/item/10050075...l.0.0.1ace4aa66dWHla&sku_id=12000041381203745
Excellent quality of manufacture! This is not an advertisement.
And once again many thanks to comrade Juan Vargas for providing the Gerber files!
Now I will wait for a scattering of separately ordered parts to begin assembly. I will definitely report the results here.
amazing Korablev hey the pads for the transformer wires I just notice that on my PCB might be a little small is ok I also order one more time the boards for the other mic body I place temporally the PCB to the other body with zip ties and it doesn't look that bad at all 😄
    1.9 MB
    2.6 MB
    2.9 MB
    2 MB
    137 KB
hi guys is about R7 the 1GΩ I was reading throughout this section ORS 87 and OneRoomStudio mention that R7 doesn't need to be exactly 1GΩ one just of a hundred of MΩ, a 500MΩ will do?
