midwayfair
I'll see if I can fix the link next time I'm on a desktop, but my username there is the same as here.
rbarreiros said:Hi,
I've been trying to find D1/D2 values and caouldn't figure them out. I realize R4,R5 values vary according to the the freq one whishes the HPF to be, but I'm failing to understand with which cap is the HPF being formed to make the math ?
Also, has anyone tested the PCB yet ?
rbarreiros said:Thanks.
I made a few pcb's to test them out, I have a cheap MXL 2006 at home, will use it as a test bed.
I was wondering what are the typical mv that the diaphragms of these mics would run at, thinking of building a Smaart test rig, injecting pink noise into the capsule input and read the preamp result.
P.S.
Got some doubts about the connections that I can't find any indications anywhere.
In the schematic there's a pad switch, one side connects to the front of the capsule/diaphragm, the other side connects where ?
The pad near the bias trim connects where ?
The XLR1/2/3 are pretty much self explanatory, the OSC pad connects to the OSC pad on the oscillator PCB, and on the oscillator PCB, Back goes to the back of the capsule/diaphragm, correct ?
rbarreiros said:Got some doubts about the connections that I can't find any indications anywhere.
django32 said:Just a word of warning, these don't fit the bm800 bodies I recently got, I think they may have shrank since the pcbs were made
django32 said:from the centre of the mounting hole to the other one its 30mm, which is a fair bit off
midwayfair said:I can't remember off the top of my head but I seem to recall the holes being 35mm. I'm worried that even if I modify the board to have 30mm holes the rails would be touching some pads, so I think I will just remove the BM800 from the list of compatible bodies. I do know the Auryle fits as of last year and that it was still the same as a couple MXL bodies.
I'm really sorry for the mess up.
At least the following el-cheapo-china-microphones have all 30mm distance:django32 said:to be fair, they could of just changed the design since you did the pcb. I'm wondering if the bm-700 or bm-8000 are any different internally? Or maybe It is worth just investing a little more money.
analogguru said:BTW, the dimension from outer-frame-to-outer-frame is approx 35,5mm.
tcookc said:I'm looking to try this build and have a couple questions, hopefully someone can help me out!
1) What component should I use for D1 and D2...I can't find that info anywhere.
2) Are R6 and R7 supposed to be 1% like in the BOM or 0.1% like the schematic?
3) Are C2-7 supposed to be 100V like in the BOM or 50V like in the schematic?
4) I'm hoping to build a stripped down version that is cardioid only with no pad, no HPF or LPF, and no patter switch. Would anyone be able to tell me which components could be left out with such a build?
