There is a 70% chance I'll be working with par-metal to make some.
studiosteve said:There is a 70% chance I'll be working with par-metal to make some.
ditto that. I'd like to see a case that would hold two of these preamp PCBs.
bongolijus said:Hi there again,
Can someone confirm these things:
1. C7, C9, C15 HT Bypass Caps 3 MKS4-.1/630/10 Wima 15mm LS - Are here enough 250VDC caps?
2. What is the value of C1 on DI PCB?
3. What are the value of these on PSU PCB? D14? D15? R15? C19?
Thank you very much.
Thanks, I will revise BOM to include PS diodes that are missing
I will have to revise the docs for more PSU info.
briomusic said:Thanks for that guavatone. Now I just need to find something for this monster of a PSU tranny![]()
raysolinski said:Hey Charlie,
Did you ever tame the high frequency rise with the edcor output tranny? I had a tough time with that using an edcor in my Drip LA2a...bass rolled off and there was a high frequency rise regardless of termination although I did not try a zobel....dropped an old utc in there and it was pretty flat so it wasn't the build. I guess if I end up doing this I could buy the sowters but they are pricey compared to the edcor's
guavatone said:Check out Sowter the 1:7 and the 7:1 redd47 transformers
models are 9970 and 9980. just use capacitor clamps to hold them down.
http://www.sowter.co.uk/cgi-bin/sh000001.pl?REFPAGE=http%3a%2f%2fwww%2esowter%2eco%2euk%2facatalog%2fsearch%2ehtml&WD=redd&PN=SOWTER_TRANSFORMERS_PRO_VINTAGE_TRANSFORMERS_5%2ehtml%23a148#a148
jyrki3101 said:HI, I have some guestions about this Orange86 build ?
1. R19-21 : 620ohm/2W.....are these values right for my dual channel build
R18 : 200ohm/2W......same guestion about these too..
2. I read " MOV" on the PSU board. Does it mean a metal oxide varistor or........if it does, is it neccessary.
3. Output hookup : should I put a jumper on the O/P polarity board where it says " link"
4. I'm sorry for my bad english, but the wiring insructions say " splice both to shielded cable" in the output hookup diagram.
Unfortunately I don't guite understand that although I look at the picture. ...Does it mean that I should improvise and make the shielding myself somehow....( from a guitar or antenna cable???).......on some other builds those wires from main circuit board to OT are just twisted pairs......
stitch-o said:One other question as I get under way.
Consideration for designing the controls on the frontpanel:
-Gain (stepped attenuator)
-DI (1/4" input jack)
-Squish - which would include a 500k pot and an on/off toggle switch
-Mic/Line(DI) switch
-48v mini toggle w/ LED indicator
-Phase mini toggle
-Pad mini toggle
-50ohm/200ohm input impedance switch ------- Ima call Cinemag today to see if this is possible with the CMMI-7C.---
the answer to this is yes. I just talked with Tom at Cinemag and this is fairly easy via a toggle on the faceplate. Switch between brown (high) and red (ct) lead, from pad PCB 'mic+'. Switch output of either brown or red is feeding the CMMI-7C. Orange (low) is constant connect from pad PCB (mic-) direct to cinemag input xfmr.
Cheers!
Another couple of questions:
C10-C14 appear to be snap-in EL caps on the BOM.
Should these have leads instead of a snap-in design?
On the BOM, the toggle switches for the POL and P48 are large and expensive.
Can I just use some Mountain mini-toggle SPDT switches instead?
6.3V lamp will be ok for T3 power indicator lamp?
EDIT: If the main gain switch is 12 positions, have those positions been measured to dB values?
I'd dig having them to label the frontpanel properly.
