I've got an original Urei 1176LN version "F". It has low output, just to get a "normal" level out of it both the input and output controls need to be almost fully clockwise. There is no compression. And if you press the Meter GR button (to check gain reduction), it pins the meter needle hard to the right. Upon opening the unit, I found the previous owner had put a 1.8K resistor across the output "C" and "+/_". I know about using a 600 Ohm resistor to load the output transformer, but not sure why he got a 1.8K there. I've removed it, and once fixed would replace with a 604r one instead. This couldn't have damaged the output transformer could it?
I was going to recap, but at this point, I'm thinking it's much more than that. Any ideas on how to troubleshoot, and what to look for? I'd appreciate anything I could check here if you can suggest something.
