zamproject
- Joined
- May 11, 2010
- Messages
- 1,630
At the end of the day, I think the most simple solution is not to buy and use "NOS" carbon comp res...
Buy new, or use metalfim
Best
Zam
Best
Zam
I am not a fan of old stuff just because its old... (I'm old).I just did a short experiment with a big 3M mechanically trimmed SATOR carbon resistor from the 40's.
Hooked it up to my Fluke wich read 3.328M
Got a heatgun and heated the resistor, I could see the resistance drop while doing it, kept going till it read 3.000M
Left it to cool and now the reading sticks at 3.129M
I'll try again on the same resistor in a couple of hours to see if I can get it down some more...
Best
Zam
is there a published temperature coefficient for that component?Took another reading and it sits cold at 3.224M now.
I did another round of heatgun to bring it down to 3.000M again
And slowly creeping back up...
just got 20 x 2.7k carbon comp resistors and all are measuring somewhere around 3.3k. the colour codes are correct for 2.7k so the values have obviously drifted.
You're right John that "excess noise" applies only when there's DC current flow in a resistor. My recall of several discussions about it (in books by Motchenbacher and others) is that carbon composition resistors are the worst in this regard, metal and metal oxide films better, but the best, having essentially no such noise, are solid metal wire-wound or foil resistors. In terms of thermal agitation noise (or "Johnson" noise, the kind most associated with resistors in audio circuits) all resistors are exactly the same, regardless of construction. "Audiophile" designers waste money when they put exotic resistors in signal paths where no DC voltages exist. But things like the 6k81 phantom-power resistors will contribute excess noise into the mic signal, so metal-film (at least) resistors are appropriate.I vaguely recall a discussion about "excess" noise in resistors.
[edit- excess noise is the noise correlated to current flow affected by granularity of the resistive media. I saw a campaign arguing that carbon comp was superior in this regard. That was the last I heard of it... not much of an issue since excess noise is down tens of dB below the signal. Perhaps an issue with resistors used with DC bias current. nah... [/edit]
