Kingston
And then I ended up adding opamp output buffer anyway. There's a whole another SID coming in now. MSSIAH supports dual SID usage. They can be used as unisono with the usual detune etc. fattening tricks. I needed a mono crossfade for the two - enter the old "crush'n'blend" building block (ie. dry/wet) . I had to adapt it to single rail use but that's trivial.
