Oven heating elements
sodderboy
GDIY Supporter
Long Island
Anyone roll their own elements for a kiln or industrial oven?  There's some schweet DIY happening in that wierd corner of the world.
I've fixed some small curing ovens  with with $7 replacements from Chinazon (vs $750 from the manufacturer) but will be rolling my own for an older 7500 watt Blue M annealing oven .
Mike
Just had a thought; how about using heating elements as a load for testing power amps? According to my calculator, a 2KW heating element at 115V should have a resistance of about 7 ohms.
It is commonly done for testing high power amps, even better water heater elements in a bucket of water.
Like a simple cooker loop as a load?  Interesting, you can burn-in an amp and make osso bucco at the same time.
I would think that toaster coils would be too reactive.
Mike
ruffrecords said:
Excellent. What kind of music makes the best toast??
With modern compression/limiting, almost anything will work:
