P&G Fader knob 3D print
Norfolk - UK
@MidnightArrakis I have just been printing some samples of the P&G knobs from the STL file you provided.
The default orientation in the 3D drawing of the knob is on its side. I assumed this was perhaps something to do with making the 3D print work properly. However. the large overhang this creates where the fader tang is inserted sagged enough to create some very difficult to remove swarf.
The second print I did was therefore with the knob face down - the orientation it would be in on a fader. This avoids the long overhang and gave a much cleaner print expect the top surface is a little more granular. However the tang would not push into the slot.
Next I scaled the width by 5% to widen the slot for the tang. This printed OK and the tang would fit in to the slot but the slot was not quite long enough.
Lastly I increased the length of the knob by 5% to increase the length of the slot. This last print looked OK and the tang fits snugly.
I notice this design of knob has an arrow on the left and right sides and a line across the centre. The 'real' P&G fader knobs I have lines down the sides and one across the centre - not really an issue, there are probably many variants. As I printed in only one filament, none of these were reproduced. To create the central line I need to find the layer in which this is printed, pause the printer at that point, change filament colour, print the line, pause again, change the filament back to the original colour and complete the print. This many changes in such a simple part is a PITA. I might try printing the knob in the line colour up to and including the line and then change the filament to the base colour unless there is some other smarter way I can achieve this.Fortunatel the knob is small so even on my small printer and can print probably a dozen at a time.
You asked if the printer worked with plain and/or binary STL files. The answer is neither. Before printing, the STL file is sliced into layers for the 3D printer to print and then each layer is converted to gcode which is what the printer understands. So it is the slicer that needs to understand plain or binary STL files. Fortunately it seems happy with either (and a whole lot of other formats too).
That all sounds really good!!! I'm glad that you were able to get things all figured out.
>> I do hope that you understand that while I am more than happy to share with you all of these items that I happen to stumble across, since these STL files are all from various third-party sources, I have have absolutely no idea about anything concerning any of these files. Anything about how the STL file was created, its orientation, its dimensions, etc., etc., etc. are all beyond my control and certainly beyond my knowledge concerning this specific topic. I'm happy to share with you any audio equipment design items just because I also simply enjoy working with you on these types of projects. That's about it!!!
Going back to the fader knob.....from what I have seen on a few online fader knob catalogs, the various manufacturers of these fader knobs seem to offer like 12 different models of a single type of fader, just to accommodate all of the various dimensional variations as you described. Meaning, in other words.....before a specific fader knob can be selected for any type of linear-fader, you need to know the "tang" height, material thickness, length, etc. in order to correctly match a fader knob to a specific linear fader assembly.
So.....I suppose that if you were to provide me with those dimensions on the types of faders you use within your equipment designs, I could then keep my eyes peeled for any fader knobs that meet those criteria.
[As I printed in only one filament...To create the central line, I need to find the layer in which this is printed] -- Again, I don't know anything about how all of this 3D-printing stuff works, but.....since the P&G fader knob that I provided you also had 4 separate files, one of which was a "Line" file, isn't there some way for your printer to print that geometry separately while also using a separate filament and that separate filament would be "BLACK" instead? Actually, I was imagining you sitting at a brightly lit workbench with a box of freshly-printed fader knobs and you're sitting there holding a fader knob in one hand, while peering through a lighted magnifying-glass and holding a delicate teeny-tiny artist paintbrush with your other hand and ever so carefully painting in the black-stripe on each and every knob!!! HOW MUCH FUN WOULD THAT BE?!?!?!?!?!?.....
Whenever I import a -- STEP/STP -- file of an electronic component, I have noticed that their incoming orientation can be "all over the map"!!! As an example, the TAKACHI enclosure imports with its "rear-panel" as being on the bottom and the small "front-panel" as sticking up into the air. The NEUTRIK connectors import in as being oriented "every which way" but making any sense depending upon the model type!!! And, while I can rotate a component around to an orientation that "makes sense" visually, even when I save the file into my SolidWorks file format, the components' -- creation orientation -- still remains the same regardless of my new rotational orientation. And, I don't know if that is a changeable feature or not. So.....I can't help you out here in this department.....yet.
ENJOY!!!
i feel like this is the exact kind of task a resin printer would excel at. they are unfortunately a lot bigger PITA to use.
Not difficult tbh. Just use a suitable stencil to provide an accurate line. Question becomes what to use for the line - ink ; paint; Sharpie ? If the line is in a groove (I can't remember) then just "paint" and wipe to leave the line in the groove. This method been used on washing machine controls etc.
Sounds like you are ready for the Bambu AMS or AMS lite ;-)
The problem I had with the resin printer was it was not as accurate - required calibration and adjustment to hit and OD then often the ID would not be correct, and changing colors on the fly is impossible.
resin/sla has come a long way in recent years. there are a more than a few hobbiest printers that blow traditional fdm away in terms of dimensional accuracy. of course, the colour issue still remains.... but the few resin prints ive had done through JLCPCB have turned out excellently, and cost very little. this to me seems like the best option, resin is pretty nasty and taking the necessary precautions at home was far too much work for my likings
Resin printers still require supports in the gaps that result from print orientation so I don’t see resin achieving something here that FDM can’t besides improved resolution. It's true that great printers of both types can outdo lesser machines from either category (on accuracy) but people need to work with the tools they have. And even expensive CNC tools require some tuning for size/fit. We can do that on printers too. Even better is designing parts that are more forgiving of size variance.
I pulled the caps off of my Alps faders and copied the geometry they have. The extra gaps to the sides of the main slot do three things: They provide some give to the walls that grip the fader slide, they keep wall thickness more uniform which improves injection molding quality, and they help reduce material consumption. There are also some keying features that accommodate the upsets in the sheetmetal tab. My first print with these dimensions fit beautifully. An STL is attached though it is disguised as a .PDF
    319.2 KB
    538 KB
    549 KB
  • Fader Cap.PDF
    22.2 KB
Some thoughts on print quality:
Due to the slot(s) fit being critical I don't see a good way to print on the side. You will also get a different surface finish on both sides this way. Even if your printer can make decent supports the slots are bit narrow to pull it out after. Some printers use caustic or even water-soluble support but those are very much an exception right now. Avoiding supports is generally good practice.
If you print flat on the bed the main challenges are overhangs, bridging, and radii that are not normal to the bed (Like the finger shaped arc most caps have). Some printers may struggle with a clean sharp upper edge too. Keeping overhang angles greater than 45 degrees can make unsupported angles achievable on most printers (though some can do much shallower angles with well tuned speed and cooling). A radius further removes overhang scenarios. A radius on top or even just a small flat might be nice option if your printer struggles with a sharp upper edge. Technically we are bridging anywhere material is printed above the slots but the distance is so short I think most printers will handle this well. The finger arc is the most troublesome. With a .2mm step height you get some free "texture" for grip but it doesn't look that great. My printer supports .08mm step heights and that can be accessed either by setting to that height always (slower) or activating "adaptive" layer heights and letting the slicer adjust. It looks a bit better.
    1.5 MB
    1.8 MB
  • Printing.pdf
    225 KB
Ya, having resin prints done elsewhere is defiantly the route I would go.
I was impressed enough with the progress in all of this to jump finally. I literally just returned a Elegooo Saturn Ultra, it made beautiful prints. :) I ran it for about 90% of its first film life before deciding to return it. I am not sure how many kilos of resin I used, maybe 15, I still have about 17 kilos of various resins left here if you decide to try. I did not try any of the water washable types. Others have commented on the smell/mess and consumables used in the process too. I ignored that, of course, and they were right. Best I could manage was about 6 ounces of 99% isopropyl alcohol, and two pair of nitrile gloves per print.
I made some awesome vintage knob replicas, but the threads needed to be chased/cut with a tap. I could nail an OD, or an ID, but not both. There is compensation in the slicing software for that, but the wide temp swings in that shop (it is only humidity controlled) meant you still had to calibrate almost every print. That is not the printers fault, and higher end ones have heated reservoir areas etc. Also, the resins I used, even the ones they called "flexible or tough" were much harder than the filaments I have used so far, but man did they feel good. Kinda like bakelite.
I have a keen interest in the powder fusion process with a laser - but I am spent out for the next couple years and we will just be using these for mounting brackets etc most likely - so no need to go nuts... so far. Plus I wanted something my grandkids could use with supervision - after the first few prints and waiting for cleanup in another room, plus not really being allowed in the print area etc, they lost interest lol.
The filament printer now runs about 50% of the time they are here, I am starting to teach them basic CAD skills, and soldering etc. Fun stuff.
Do you have a link to a drawing of them?
That's the next step. I have a poor wounded 8 into 2 EAB RE-85 mixer and I need to rebuild the back metal work with XLR parafeed direct outs and pans etc. So when I saw your thread I thought about all the obsolete, missing knobs I have and how I should go about getting an accurate diagram of them.
I must say I find your contributions and guides immensely helpful Ian especially now while I am restoring some classic old gear. I'm lucky in the Hastings area that there are a lot of companies for electronic pcb's, independent reel to reel technicians, specialist metalworkers and the huge Penn Elcom but obviously I need to get organised with the plans.
I've seen "Matter Hacker" software that can take photo's and help turn them into 3D drawings so I've found some Mac OS ones to learn on. Apologies for my naïveté. This side of things is all new to me but having spent 30+ years in Studios I have a good feel for form and function.
[I need to rebuild the back metal work with XLR parafeed direct outs and pans etc.] -- (In a "Mighty Mouse" voice): "HERE I COME TO SAVE THE DA-A-A-AYY"!!! ..... Take a look at my sheet-metal design work in the link below and determine if this is the type of help that you need in rebuilding your back-panel metalwork. If so, send me a PM with as much information and photos as possible, OK???
https://groupdiy.com/threads/thinki...anel-manufacturing-service.86050/post-1133167
>> Is your EAB RE-85 rear-panel like this???.....
No It's a lot of small din plugs in a DIY trench. I think someone made a small mobile mixer from some spare channels many years ago from what ever MDF was called then and metal and painted black. I want to keep it all tube so need new bigger trench and sloping back to put in all the transformers and tubes etc. A bit like the Sphere one on instagram, keep kind of classic Siemens/Telefunken looking.
I expect there are quite a number of similar 'classic' mechanical parts for which no proper drawings exist. One route forward would be the get them 3D scanned which should create a base line shape. Then all that then needs adding is the aperture for the attachment to the electronic component (fader. knob etc). I know 3D scanners exist but I have zero experience of them. Maybe someone here has the capability or access to it?
Thank you for your praise. It is always good to know your efforts are appreciated.
I used to live near Cambridge (Neve country) where all those crafts existed in spades. Up here in the wilds of Norfolk they are very scarce. Fortunately most things can be done online these days.
It is new to me too but great fun learning.
[It's a lot of small din plugs in a DIY trench] -- Well-l-l-l-l-l-l-l-l-l.....you can either make a bunch of measurements and take a bunch of clear and well-lit photographs of what it is that you currently have and want to have done, so I can design something that you can have made -- OR!!! --.....you can try to have whatever it is that you currently have 3D-scanned and then have it 3D-printed.
Personally, and unless I am totally missing something with how 3D-scanning and printing all works, I can't see how having what you currently have 3D-scanned is going to help you because by doing so, you are scanning -- what you currently have -- and, you want something that is -- DIFFERENT -- than what you currently have!!! Has this technology become so advanced that you are able to 3D-scan an item in one condition and then have it 3D-printed in another condition? Is that done using the new AI technologies?
FWIW.....I would suggest that you take a bunch of photographs from several different angles, while also providing a bunch of basic mechanical measurements so I can have a rough idea of panel height, width, connector spacings, types of connectors (i.e. power, inputs, outputs, any D-Sub's, etc.) and anything else that may be pertinent. The more information provided.....the better!!!
[need new bigger trench and sloping back] -- Please excuse my ignorance, but I am unfamiliar with the term "trench" when it comes to the mechanical design details of a mixing console. Even though we both may be in the same audio industry, we both also use completely different terminology for some common items, such as:
---U.S.------------------------UK
Standoff ---------------------Pillar
Mounting Hole ----------Fixing Hole
Bathroom -------------------Loo
So.....how about if you just draw up a sketch of whatever it is that you are needing and mark it up with some basic dimensions? That will give me at least a starting idea of what it is that you are looking to have made for your mixing console.
[to put in all the transformers and tubes etc.] -- How about creating a list of the transformer manufacturers and their Part Numbers? And, then.....either some photos and/or a sketch of how and where they're supposed to go and be mounted? The same goes for the tubes.
And, finally.....if you haven't done so already, take a look at the contents within the link I provided you in my earlier response. I can't help you, unless you can help me.....at least get started!!!
"[I need to rebuild the back metal work with XLR parafeed direct outs and pans etc.] -- (In a "Mighty Mouse" voice): "HERE I COME TO SAVE THE DA-A-A-AYY"!!! ..... Take a look at my sheet-metal design work in the link below and determine if this is the type of help that you need in rebuilding your back-panel metalwork. If so, send me a PM with as much information and photos as possible, OK???"
Well I'm working with local businesses or as local as possible, I have a clear idea of the parts and I have most of them in stock, I'm just waiting for a couple of transformers and then it will be point to point wired, I'm in no hurry. I originally only referred to the 70 year old fader knobs but I have a solution in place now. Thanks for the pitch though!
I missed / can’t find the original thread Ian mentioned, but I am very interested as I need some of the wide P&G knobs and they’re expensive to source in the USA.
The conversation originated in the groupdiy 500 series specifications discussion so I moved it here. Here is a link to the mid part of that discussion:
https://groupdiy.com/threads/groupdiy-500-series-mechanical-specifications.89790/page-5#post-1188647
If you go back a few post you will find the original fader knob .stl file posted by @MidnightArrakis
It is a zip file containing various versions. All I did was tweak the scaling so the slot would fit the tang on an ALPS K-Fader.
