letterbeacon
I thought I'd start a new topic as the previous one was more about finding a schematic, whereas this one will hopefully be a discussion about building a REDD 47 pre amp point to point. This is my first point to point project so I have a few questions, some that may be obvious to more experiences posters, so please be patient!
It looks like the original schematic, dated 01/10/1951, is available here: http://www.sowter.co.uk/schematics/EMI-REDD47.pdf and there is a redraw with component layouts here: http://www.twin-x.com/groupdiy/displayimage.php?album=322&pos=0
I've compared the original to the redraw and the only error I can see on the redraw is that the resistor on the E88CC should be 8k2 rather than 82k.
Comparing the schematic to the component layouts, I have noticed a couple of descrepencies that I'd like to run by you guys.
- The input transformer on the component layout has a 20pf cap with a 32k resistor in series where the schematic calls for a 100pf with a 100k resistor in series. Is that because whoever drew the component layout is using a Cinemag transformer? What are the purposes of that capacitor and resistor?
- The power supply section calls for two 1N4007 diodes on the component layout, but they aren't on the schematic. Is that because originally the power was already rectified DC from the desk?
- On the schematic, the two 47uf caps have their positive leads connected together as well as by a 1k 2W resistor, however on the layout they're only connected via the resistor. Is there a reason for this, or is it a mistake?
Do you think I could run two pre amps from the one power supply?
That's it for now - thanks!
