iampoor1
Hello
I have some Gates broadcast mic preamp cards with a fixed 45db of gain. I think they sound great, but I want to add some sort of gain control, without modifying the feedback loop, or simply putting an attenuator on the output. They have very low headroom.
The mic preamp input transformer is designed to see a 150 ohm source impedance. I have added phantom power, and am assuming the easiest way to adjust the gain would be to add a fully switchable H-pad at the front of the preamp, using a 4 pole rotary switch to change the values, hence the proper impedance relationship and balancing can be kept. AM I missing any potential pitfalls with this method, or does anyone have a suggestion for an easier method? Lots of offboard wiring with a 4 pole rotary switch on this one...
