I stand corrected for 1/2 the diodes. :-[trobbins said:Moamps is right, there is a paralleling action going on for the negative half diodes in the two bridges. Both loads would need to be isolated (pos and neg rails) for diode currents to be separated.
Any wire resistance in series with these parallel diodes will degenerate temp related current hogging. Diodes have the bad characteristic of lower junction voltage as they heat up, so do not automatically share nicely (all else equal the hotter diodes will draw more current), but any resistance in series (like wires or PCB traces) will counter that current hogging. (I would not add series resistance to force sharing, if anything I'd be tempted to oversize the diodes.)Symmetric wiring and traces and bridges would be needed.
I'd be more concerned about the stress on the regulator at start up if those are valve heaters - and the regulator heatsinking will be a concern just for continuous current if there is a fair bit of transformer winding headroom to cover mains variation.
