Hello!
I am putting together an AC coupled Cathode Follower based on a 6922 tube as below...
As the 6922 has parallel heater connections only, I would like to use the other triode in the bulb in parallel. Could anyone advise how I should connect the second triode? Do I just connect anode to anode, grid to grid etc? What changes do I need to make to the values of the resistors to retain correct operating points? (R15 is the resistance I found I needed to remove the bass response peak with the transformer the CF is driving)
Also, Is there any advantages/dissadvantges to paralleling the second triode in this circuit?
Ray
Ray
