James HE
I've been looking around and researching parametric eq circuits. The main purpose will be for amplified acoustic guitar, I want something that I can control before the board, so basically a guitar preamp with many eq bands. I'm a newbie to electronics, this will be my first build.
For the Eq section I think I'll try this from ESP.
http://sound.westhost.com/project28.htm
This design seems very compact compared to others I've seen. I'm thinking this will be in a larger stompbox housing as long as I can fit all the knobs on there. If it ends up rackmount that's ok. For a pedal version I might skip the low band and just do a hi pass filter via a switch.
I have a lot of questions at this point.
Since this will need a high impedance instrument input, I need to change the input stage. Do i get away with just using a different opamp for more gain? or should I take a different approach with a different gain stage all together? One of my acoustics has an active preamp, another dosen't, Hi and low inputs would be ideal here, or maybe just something that can handle both.
Opamps:
The author recomends Tl072 for the simulated inductor stages, NE5534 for the output stage. Any different suggestions in light of it's intended use?
the power rails - this is more of a general question. I'm confused about powering opamps with double vs. single ended supplys. Some scematics I've seen have the Vcc- pin to ground, some to the V- rail. Is there an advantage either way? From what I've been able to dig up, opamps are designed to run on double ended supplies, but that single ended is fine in some circumstances. I stumbled upon a TI paper on this subject, but really it confused me a little more (not understanding the vitual ground concept)
I just wanna know should this have a + and - rail or just + and then to ground. I'm pretty lost of the whole power situation, Battery power seem's easy enough though.
Opamps:
