Strawtles
- Joined
- Mar 20, 2009
- Messages
- 191
Hi. I want to build a relatively simple passive monitor controller with a switch to select three balanced inputs, a 4 gang attenuator and another switch to select three balanced outputs.
My doubt is how to split the balanced signal before the attenuator to send it to the headphone amplifier (with unbalanced inputs)
Is it better to use two transformers or an active circuit?
Below a sketch of the block diagram
