hmm... transition connector could work.... it's just a shame that they can't be laid out side by side, tracks paralleling each connection, because xlr takes up the entire span of a parmetal enclosure. what really stinks, now that I *just* realize it, is that pcb mount xlr connectors for 16x2 require a 16.38 inch board. thats big, and could get expensive to fab. maybe a 2u project, with a transition connector from bottom pcb to top, 8 xlrs on bottom, 8 on top, d sub off to the side on the bottom? That would make a bottom board of about 14 inches, top board (with outputs) of 9 to 10 inches.
anyway, I just wrote all this, maybe its of some use:
if anyone has corel draw, i mocked up some things, with dsub holes being done up to scale from Amp model 788751-1 on mouser. Neutrik holes are according to their DXF files from model number NC3FAH1, and panel is indicated with yellow lines. bear in mind this takes out one or two of the neutrik supporting holes to accomplish both on the same.
the trace version got hurried at the end. lines are 1 pt, which i suppose means nothing. I have no clue what kind of track spacing is possible/optimal/acceptable. I have no clue about pcb's, just had a hunch that these could both fit on one board. anyway,, they're at:
http://www.enthalpystudios.com/diy/passive8chanwithtraces.cdr
and
http://www.enthalpystudios.com/diy/passive8chanjustholes.cdr
Hopefully it helps somehow.
Anyway, I'm very interested in a pcb with dsub holes, 16, 24, whatever.
Also, this is layed out with just a tiny bit extra spacing than neutrik recommends as minimum for these connectors. they say .906, i did .91 inches. That definitely fits 18 xlrs on the back (not much else, however)
Only two options I'd care to see, IMHO, are LCR switch (or mono/stereo per pair of inputs, like a d4ng3rous box), and a mute switch. Or maybe instead of the mute switch, at least a switch that routes inputs 1+2 direct to the outputs.
LCR probably needs rotary or a stupidly expensive (for pcb mount) toggle. Maybe just pads for user choice, or with some clever track routing (i think) a mono/stereo switch per input pair could be done.
i dunno.
billy
