Another product availible in the US is called Humiseal. It sounds similar to what Jakob describes. You could also plate your traces with electroless tin, which is a very easy process and is probably a similar protection scheme to what Neve and Ampex did. I suspect that Neve used a wave solder technique, but getting tin or tin/lead on the copper by whatever means is really the point. FWIW, I would never leave bare copper on a board that I made. Copper is very easily oxidized and IIRC, is not "capped" by it's oxidation layer and will continue to oxidize through the bulk over time.
Regards,
Chris
