Neeno
Hi guys...
I'm working on a api 500 series pcb.
As I can see from the specifications the psu and the audio gnd is separated on the edge connector and i know that is a good practice to keep them separated and to join them on the star ground.
I suppose that the star ground point is should be inside the lunchbox.
I would like to use 2 ground planes one for each layer of the board, one for the psu (top layer) and one for the audio gnd (bottom layer) and then connect them to the edge connector separately; pin5=audio gnd, pin 13 for the psu gnd.
Now some questions:
1- Would it work ???![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
2- Would the groud planes make the board act like a capacitor ?
3- There is a better solution ?
4- If yes, what's the best solution ?
Thank you for your help !
Now some questions:
