Bo Deadly
Does anyone in the US lower 48 want a few of these PCBs? I was going to post this in the WhiteMarket but I'm not selling boards and never will. I'm giving theses puppies away and I'm going to pay USPS envelope rate which I'm assuming should only be a dollar or so.
I have ~8-9 of each of these 11 boards:
LA3A Gain Reduction Amp / Autoformer Drive
LA3A T4B / Autoformer
Pultec EQP1 Filter / Controls
Neve Input Transformers
Neve BA283 AV Gain Stages
Neve BA283 AM Output Driver
Neve Output Transformer
Dual Voltage Regulator
Pultec HLF-3C
Transformer Input/Output
THAT120X/THAT1646 Input / Output
Here's a PDF of the schems:
PcbStac 1.0.5 Schematic PDF
And here's a PDF of the gerbers:
PcbStac 1.0.5 Layout PDF
Note: To really view the schematics and layouts close up, you have to download the PDF and zoom in 400%+.
ERRATA:
The second transistor base (center pin) is incorrectly connected to the 3k3. It should be connected to the collector of the first transistor as shown in the following graphic:
The recommended fix is to float the middle lead of the transistor and use a small piece of bus wire to bridge the circuit.
The TVS diodes SMBJ15CA are pretty high capacitance (although it didn't stop Rane from using them). There are now low capacitance TVS diodes like CDSOD323-T12C-DSL. The package is much smaller but with care they should fit. Or just leave them out (the THAT chips have decent protection already).
Pultec HLF-3C
ERRATA:
