I have an old Lexicon PCM70 that is acting up.
The LED display lits up all the way,even with no input.
The unit passes dry audio when I set the wet/dry mix to 50%.
It looks like all the menus and display is funtioning properly,but no effect comes through.
When I set the MST LVL (master level) to less then -16, the LEDs turn off,and the meter shows the audio input as normal.
The voltages seems normal,+15V,-15V and +5V are within normal limits( about 2% off at the most).
Tried to replace the lytics, but no change...
The backup battery seems OK (3V).
I have also done the reset procedure,with no luck.
Has anyone had this problem?
Can it be the bypass capacitors in the digital section? They are little green ones...
Or is it more likely that some of the IC`s are broken?
I have read that the IC sokets in old Lexicons oxidize, what cleaning solutions are recommended?
Does anyone here have the schematics? (please PM me if you do)
Any help is really appreciated!
Kåre
Kåre
