The man is very charismatic. He did not do this as an advertisement for new products, he talked about capacitor testing and wire testing and opamp testing and any device testing. Looks like he likes polypropylene or NFO ceramics best for coupling caps, no surprise. He showed how oil/paper caps suck, no surprise. His test jigs are all "analog" with scope horiz and vertical doing a form of transfer function analysis and the opamp to raise the gain up. Audio precision's order of magnitude for THD+n is so high that you have to amplify before putting it into it, no surprise.
To test the opamp he takes advantage of its own noise gain and uses a simple oscilloscope and a triangle wave is best, it produces a rectangular block on the screen and the smaller the block, the lower the distortion+noise of the D.U.T.. When I get a chance to scan his poop sheet on the schematic of how to analyse opamps and caps, but I'd not be surprised if on his website you can also find it.
Only if you need it, his email is rap[at sign]galaxy.nsc.com but first go to www.national.com/rap and search for
LM 4562 Data sheet (this is the new super low noise and distortion audio opamp). His challenge is for you to put 10 in series and see if you can hear a differene. With gain/atten/gain/atten etcetera, lather, rinse, repeat.
LM 4702 (new linear audio power amp/driver, to be followed by some Darlingtons)
AN1490 is the app note.
That's it for now!
That's it for now!
