Johnny1234
Hi all it''s been a while.
I am working on my Peavey VMP-2 pre amp.
The problem is it has a flat response at 1kh but falls down 6db at 300hz on channel one.
EQ and filters are off.
Oh no!
Relays all fire and switch from one pole to the other.
Swapped all 4 tubes from one channel to the other ....Same problem
Changed all 22uf 25 volt (circled in diagram) ....Same problem
The jumper on both channels is bypassed leaving C164 open circuit.
All plate to ground, and grid to cathode voltage are within reason from one channel to the other.
Starting to get baffled....
Diagram is attached
Any ideas greatly appreciated.
Oh no!
Diagram is attached
