Pentode Control Gain by Screen Grid
opacheco said:
PRR said:
> Another idea - use G3 instead of G2!
Same main problem: the plan Opacheco has shown us is a feedback amplifier. Gain is controlled by the feedback resistor ratio, not the tubes, or not until the tube is de-biased so far you might as well remove V4 and go right into V5.
I made a mistake. With the 300 ohm pots turned to maximum gain, the 200K resistor does nothing, but the 400K||1.25Meg resistors are still applying NFB. Minimum gain is still 800, 58dB, but maximum gain is 2,000 or 66dB (plus typically another 20dB in the input transformer).
Changing 200K to 20K reduces min gain to 38dB (a useful value in modern studios), but max gain is still 66dB, a long span from 38dB. With the simple linear pot it may be hard to set low gains like 40dB and 45dB. If 66dB (+20dB) is more than you could need, also change the 400K to maybe 100K. That gives min=38dB, max=54dB (58dB-74dB with input transformer).
Getting the 35dB-55dB gains you need around loud instruments, without trouble from microphonics, really requires a re-design. The tubes could be re-wired as Triode, two triodes is plenty of gain and less working parts to shake and make bad sound. The input cathode resistor could be larger, perhaps 1K with no cathode capacitor. Then the 400K could be replaced with 500K audio-taper pot.
By the way, there is no "DC feedback". Although there is DC at some points on the NFB network, the amplifier has no DC gain (5.6nFd cap blocks DC).
That's a lot of output capacitors. The 8uFd must be high voltage, so it could be expensive to use a bigger cap. Instead the NFB loop corrects any bass-loss through the 8uFd. The NFB network would leak DC from V4 cathode to output. The 24uFd blocks that, and because it is only 1V here the 24uFd can be smaller/cheaper than a high-voltage cap. But then why the 10uFd cap? Perhaps to compensate bass loss in the 24uFd cap. But only if the load is low impedance. And the cathode follower will not drive a very low load impedance. While it seems expertly designed, I don't understand some of these choices.
Firts,
Thanks a lot for your analysis!!!....This unit Don't have any input transformer at all!!...Why do you thinks so?.
This unit is designed for a linear response from 10Hz to 2000Khz +/-0.5Bdb!!..Amaizing, do you?
and was used with 50Ohms load.
"The 24uFd blocks that, and because it is only 1V here the 24uFd can be smaller/cheaper than a high-voltage cap. But then why the 10uFd cap? "
I believe, the 10uf is for DC blocking from the 300Ohms resistors conected to the V4 Catode and the V4 Catode and V5 Triode Catode are DC conected by the 1.25MegaOmhs(I very little DC current).
By the way how do you make this kind of calculations gains???....do you use a specific network analysis like Feedback Amplifiers Method??
Thanks a lot again.
Opacheco.
Ey PRR do you have any comment??.....
Opacheco.
Personally I have always used a piece of paper and draw load lines to figure out bias, voltage gain etc - it is probably more long-winded than using software, but who wants to be shackled to a computer when you're doing electronics anyway  :p
http://www.aikenamps.com/LongTailPairDesign.htm  << this site has some very good stuff under 'Tech Info'
http://www.freewebs.com/valvewizard/pentode.html
HTH
Darren
HTH
Darren
Ok Thanks
Opacheco.
Well,  I had do a Feedback Electronic Analisis using the mid frequency small signal equivalent theory for the 6Au6 and 6U8 GE and Sylvalnia tubes data sheet as following:
6Au6
gm=3900 m mho aprox.
rp= 500K ohms aprox.
6U8
(pentode section)
gm=5200 m mho
rp=400K ohms
6U8
(triode section)
u=40
rp=5K ohms
The result indicated to me the 200K ohms of the feedback network will be change to 20K ohms and the 400K ohms of the feedback network to 80K ohms I get a total gain of 35db to 56db when the 300ohms pot goes from the 0 ohms to 300 ohms. That is a good gain for instrument and mic preamp too, but I have a mismatch impedances from the output to the low impedance input(digi 002 or wherever mixer or A/D converter before recording sistem).....the output impedance for this tube pre is 50 Ohms aprox., what can I do in order to match this output impedaces to mixer impedances???....Transformer may be??...Which one???....How about if I take the output form the another part of the network????
I would like to post my analisys work but there a many pages(15).......I will tray to scan them.
Any comments will be apreciated,
Thanks a lot,
Opacheco
Dear PPR, I wanna be greatful, I forgot to say ALL YOUR ANALYSIS WERE CORRECTS!!!.....please forgive!!.......But how did you do that calculations so quickly!!!!....I needed a very concentrated analysis and some laborious hours in order to get the same results!!.
Now I have a new trouble with this preamp because I have a Mismatch output impedance. i wolud like to use this unit like mic preamp and line in order to feed a pro tools recording sistem, What can I do in order to get the matched impedances????....transformer???,....Which one??...the output impedance for this preamp is 50 Ohms aprox in my notes.
Thanks for your time and dedication in all question in this forum!!!!!!!!!!!!!
Opacheco.
