Andy, -do you know who did the phantom power design in the SSL9000 console? (it's in the little 1RU system supervisor...)
Anyhow, I ask because there's an age-related failure of a 1KΩ power resistor (it bakes and dies, and it's the series resistor in a series R/shunt Zener regulator that powers the opamp that drives the regulator).
When the resistor dies, the regulator sends the full, unregulated voltage to the phantom rail. (about 90Volts! :shock: )
We discovered this when it failed on one console and tore up EVERY SINGLE ONE of the input phantom-blocking caps on the console mic-pres. (they're 0.1% selected, matched pairs, so they're not cheap, either!) they're rated at 63V, and after they go, you lose the MAT-02s. When they go, you usually have a 50% mortality rate in the first pait of 5534s... -That was a pricey little failure... however on the bright side, it's when I started to look closely at the workings of the 9K mic preamp, I was VERY impressed with it, and one thing led to another... you can guess the rest! :wink:
-Just curious who I should send the bill to! :wink:
Seriously though, I have 3 x 9000 J series here, and after that happened, I pulled both the other supervisors and found the same failure about to happen. In each supervisor, I replaced the 2-Watt resistors with 10-Watters and haven't had a failure since. I then told all of my buddies who look after 9K's to do the same, and they all reported heavily scorched-looking PCBs under the resistors...
Pucho, if you read this, perhaps make a note and perhaps you or Brian should take a look at your phantom rail PSU. the resistor is inside, towards the back, toeards the left. While you're at it, take a look at the row of axial electrolytic caps, make sure none of them look dodgy, the heat from the resistor usually partially cooks the closest one, as reported to me by a couple of other 9k-obligated techs.
Keith
