[quote author="SSLtech"]Ah, it's simple enough... a standard bridge rectifier and smoothing cap arrangement, into a pair of positive and negative voltage regulators. This is the absolute most basic, straighforward regulated ±18V supply that you can build.
On to the above, the thing that makes the KPS-1 unique is that it uses a diode/capacitor arrangement rather like a voltage multiplier, but it draws from
both legs of the AC supply, not just one or the other. Since the positive side alternates from one leg to the other, this method works much better than the usual single-leg voltage multiplier, since it doesn't spend 50% of the time doing nothing at all... (the AC voltage spends 50% of it's time in the "wrong" polarity, so nothing happens, requiring larger capacitances to keep the charge from decaying)
It's no more difficult than most voltage multipliers, plus it's compact... I like it (but then I'm biased! :wink
Keith[/quote]
Ahh, well, the +/-18v part I'm perfectly comfortable with... I whipped up a +/-16.9V unregulated supply out of stuff I found in the junk box the other night. It's only unregulated because I dont have any 7815/7915s on hand, but that'll change soon. The bit I'm not all that comfortable with is the voltage multiplier part. Is your design open enough that I could peek at the scheme?
