3ch Phantom Power Supply Switcher
If you want it to be usable with any preamp without needing to know details of the pre-amp input circuit you should have DC blocking capacitors so that 48V is not applied to the input of the preamp, and you should have protection diodes. Typically protection diodes would dump fault currents into the power supply rails of the preamp, but in an external phantom power supply the only thing you could do is have some kind of voltage clamp, like a transient suppression diode (essentially a high current zener style device).
dc blocking caps between input and output
Yes.
a zener in line with the +48v
No, something like the figure 24 from "The 48V Phantom Menace Returns" paper from a few years back.
Looks like ThatCorp fixed their website problems, it is available again here.
Something like this, but I would probably use lower than 18V TVS in this application, that was chosen in the context of using a That pre-amp chip which was probably powered from 15V, but could take up to 20V max on the power pins, so 18V TVS would not get triggered by the 15V supplies, but would turn on before hitting the chip max voltage rating.
