featherpillow
I searched the board for something similar to this, and couldn't find one. I thought a few people might find this useful.
Here's a simple JFET phase alignment circuit. It's not anything fancy, it gives a full 360 degrees of phase rotation, which might be a bit of overkill for the studio. If you only want 180 degrees of phase rotation, eliminate Q2 and associated components. It uses a dual ganged 1M pot for R5, which should be changed to a single 1M pot for a 180 degree version.
Idss is about 3ma for the first stage, and 1.5ma for the second, given a 15 volt supply. The FETs I used for this are 2N4416's.
