THE BAD DOGS
Active member
I’ve buyed a Soundcraft 600 in working order, just two owners before, always in quiet studios. Reading all the threads I want to mod it in this way :
• Put transfos in input line modules as describe here by Jensen :
http://www.jensen-transformers.com/as/as003.pdf
They have a plug and play box they sell :
http://www.jensen-transformers.com/datashts/pi2xx.pdf
In fact Jensen transfos are expensive so I prefer to do it my self with Edcor Transfos (10 U.S.D. each) in a steel box :
http://www.edcorusa.com/Products/ShowProduct.aspx?ID=287
• New ground schematic as describe here :
http://www.tangible-technology.com/articles/200b.html
• Change the caps, a lot of thread about, perhaps I will chose this way, because the man had worked for Soundcraft on the design of this consoles :
http://forum.analogconsole.com/viewtopic.php?f=25&t=732
• Changes TL072, there’s so many opinions, and problems with oscillation, caps, instability, upgrading power supply to support modifications, etc… somethings not usefull for me. So I think I will test the TL2072, who’s perhaps not the best but sell as a direct replacement by Texas Instruments :
http://www.digchip.com/datasheets/download_datasheet.php?id=980724&part-number=TLE2072ACD
• Put an A.P.I. output module in the master section like this :
http://classicapi.com/catalog/product_info.php?cPath=22_46&products_id=81
• Upgrade the power supply, but I’ve no idea how to do it?
• What about buffering the vu-meters?
So my questions are :
• Does this project make sense for you?
• Did you have opinions on my choices?
• Did you have another ideas?
