idylldon
[quote author="Echo North"]Another question:
For the phase the three wires coming from the xlr input go to one side of the DPDT switch and then I connect the three coming from the gain knob to the other side?
I do that but have no signal...how should I be hooking it up to the DPDT switch?[/quote]
Those diagonal lines are jumper wires. The ground wire from the XLR is not needed on the switch, but you should use shielded cable for the run between the XLR connector and the switch. Ground the shield only at the XLR end. If you use Neutrik connectors that have a ground tab on them, you can use the shield wire as a jumper between that ground tab and pin 1 on the XLR, killing the proverbial two birds with one stone.
If you mount the switch with the XLR wires pointing up to the top of the chassis, then the phase will be:
Switch down: normal phase
Switch up: reversed phase
Don
Don
