Milkmansound
so I have done a search and I found a wealth of info here about the electronic aspects of racking my 2 modules up. I am leaning towards the linear 48VDC supply from digikey, and using the diode method to bump the voltage down to 44V. Which leads to question 1:
does anyone have a part number for the necessary rectifier diodes? Or an electronic value so that I can order them with the power supply?
Next subject will be the case - I was thinking of getting a standard 2U rack box from Par Metal. My plan as of now is to take put the PCB's onto standoffs in the case and extend the leads to the pots to the front of the case. And I think I will add DPDT switches for the EQ and Phase (well, I may need a different amount of contacts for the phase switch) I will probably wire tie the transformers onto perf board - I hope to have some output transformers as well if things go as planned. Has anyone here racked PM1k modules this way? I am trying to make this as painless as possible - so I will probably take the big leap into having the panel drilled for me by FPE or a similar service.
if anyone has some advice, or pictures/descriptions of theie methods I would be thrilled to hear them before I place an order. I will probably begin the process next week. Thanks!
