Excellent work...
radiance said:I might go the relay way as well. Did it make a difference "hum wise" compared to rotary switches & unshielded wire?
Duct is also very cool. My power switch is located at the same location but my audio wires are a little further away from it. So far I've had not much hum.
Still...I might go for the duct anyway![]()
Ptownkid said:Did you happen to notice that you are missing a w on the right hand slow?
creal said:i like to know is you use the original time constants of farchild.
Kingston said:creal said:i like to know is you use the original time constants of farchild.
No way! Most Fairchild 670 time constants are completely pointless in this day and age. There is no material I know that needs a release time of 20 (or even 5) seconds. The meter just sits buried and doesn't move, nothing happening.
emrr said:Feedforward versus feedback should have microscopically faster attack time and feel different in nature. I haven't yet tried it with this type unit to comment realistically.
I once tried feedforward on a prr varimu built (modified for pcc189 tubes but prrs sidechain)and the result was anything but subtle. The compression was higher ratio, it sounded kind of "jumpy" and with a lot of gain reduction I had negative ratio (more input resulted in less output). It sounded pretty interesting untill like 6 or 7 dB of gainreduction but then it got weird. It needs some careful implementation for sure. Gyrafs varimu works with feedforward, I think, and it obviously works well.That way sidechain only ever amplifies unaltered input signal, and that (rectified and time constant filtered) moves the grids for compression. Should make for a pretty subtle and natural compression performance.
It sounded for me, that FF was even a little bit slower on the attack than FB, but I never measured.Feedforward versus feedback should have microscopically faster attack time and feel different in nature.
ChuckD said:If you want the M/S relay based design I think I posted it somewhere on the main thread when I did mine. I have an eagle file somewhere for it just throw me an email. It works great for me.
mrclunk said:Did you go with the original tubes? Did you have to match them carefully?
hop.sing said:with a lot of gain reduction I had negative ratio (more input resulted in less output). It sounded pretty interesting untill like 6 or 7 dB of gainreduction but then it got weird.
I'm afraid I still lack the skills/webspace/will to post audioclips. Let's just leave it to the statement that it sounds like it looks.
What a beauty!Kingston said:
