[quote author="bcarso"]I'm becoming convinced that people have used biased electrolytics* and shunned bipolars based on theory. And the theory is seductive and plausible. It just happens that (probably) with the double-foil integral construction bipolar 'lytics, it is incorrect. At least, based on measurements by the likes of Bateman, it is incorrect for minimizing distortion.
If one prefers the sound anyway in a given case, perhaps it is due to liking some 2nd. Perhaps it is due to the second harmonic at one stage cancelling the opposite polarity second in a later stage. Can't argue with what someone thinks sounds good.
*No one argues of course that allowing significant reverse-polarity bias on a polarized electrolytic is a good thing. That gives one distortions (and d.c. leakage) that are easy to hear and to measure. I'm referring here to the bias at the center point of two series-connected back-to-back polars in a bipolar coupling situation.[/quote]
Ok..after a little hunt (I'm a new guy) I found the articles but then I had to know who wrote them to read them so...... :?: I'm just going to cut to the chase and ask here about what I find confusing.
Is somebody suggesting that two series electrolytic caps connected in opposing polarity (+ to + or - to -) with that mid point properly biased with DC voltage relative to both ends, will generate audible distortion?
If both caps are properly biased and never reverse their terminal voltage they should be clean, or as clean as such things are. Putting them in series should not change that. Note: I'm not arguing that this is worth the cost of a resistor, but I don't see the harm from doing so.
