dirtyhanfri said:I reversed connection in pins 1 and 12 on one channel and it seems to be working fine as far as I can tell listening in my bench monitor... ;D
Sounds like you fixed it.
ilfungo said:give me some advice?
2 XSM 10k/10K
2 XSM 600/10k
2 Jensen 11p-1 10k/10k
What do you recommend to use as an input and an output?
thanks
dirtyhanfri said:Well, Everything Looks better now, nice boost and cut, I was reversing the high boost and cut switches, also, the bypass issues are gone, but some hum in the unit, gonna work on the wiring for tidy up a bit everything...
dirtyhanfri said:I'm not using input transformers by the moment, actually just taking + from the balanced input (I'd like to make a 2 channel ballancing/unballancing amp based on 5532's posted in this forum by audiox). The tubes are old RCA's, and I think the hum was related to the messy wiring inside the box.
Also I noticed when putting my hand near the wires going to the trimmers it makes some kind of noise, hoping it's nothing relevant qhen it's closed and racked, but, maybe is because the wire, I got for free a coil with hundreds of pure copper wire, like 1.2mm diameter and semi-rigid, ,maybe it's not the best wire to use in audio circuits?
Gonna work on the front panel today, photos coming soon
