theaterguy
Active member
Yeah, the front panel is indeed "finnished". Jättebra.
G-Sun said:Would you say a 2ch pulteq is suitable for masterbus?
miszt said:I'm looking at trying my hand at a point-to-point MEQ, but I'd like to start out with an opamp gain stage - and then possibly switch it out for a tube gain stage at a later date;
can someone point me in the direction of a schematic that would work for this idea? (ie so i can switch the opamp for tubes without having to change anything else)
(or even a FET gain stage maybe? but something fairly simple, i don't need gain control except via the filter section)
ForthMonkey said:Here is my finished Poorman's Pultec!
Big thanks to ruffrecords!
https://www.youtube.com/watch?v=VExQo2mWuXc&feature=youtu.be
ruffrecords said:ForthMonkey said:Here is my finished Poorman's Pultec!
Cool video. Would you like to send me some pics of the finished unit so I can get Pierre to add them to his gallery of projects based on my desings?
fragletrollet said:If I wanted to use a CAPI VP312 as makeup gain for the 3band pultec (afaik the same as this one but with included mid and greyhill switches footprints..?), how would I go about?
fragletrollet said:Ok. Somehow I imagined I could run the eq into a passive DI, then into the VP`s. Maybe you have a link to a schematic of some sorts? Don`t know what to look for 8)
ruffrecords said:Lovely build. Do you also have pics of the guts?
Humner said:ruffrecords said:Lovely build. Do you also have pics of the guts?
Here is one.
